Date/Time: Wed, 14 Oct 2026 06:39:10 +0000
Volume by price and data query
View Count: 1164
| [2015-01-08 15:33:49] |
| darkpool - Posts: 39 |
Hi Sierra, Lets say I have several years worth of data for a specific instrument, but on the current chart I have set the days to load to 100. I then add a volume by price study with 'volume graph period type' set to 'Start date to end' so that the volume profile needs to display more than 100 days of data. Basically what I would be trying to do is have a volume profile displayed that would take into account several hundred days worth of data,....but displayed on a chart where the 'days to load' is much less than that. This is all under the assumption that I already have the requisite data available,...I am just choosing not to display it on the current chart. I just want to confirm that is the way Sierra works in that situation. Hope im making sense. Thanks. |
| [2015-01-08 17:30:14] |
The Volume by Price study will not use any more data than is loaded in the chart.
