Date/Time: Sat, 19 Sep 2026 00:08:19 +0000
ACSIL - Get date for Reference Chart data
View Count: 3467
[2015-01-08 06:15:54]
ejtrader - Posts: 689
SC Team - Trying to find a way to calculate the Bar Date Time for the corresponding index on referenced data. However not sure what the syntax/function to use to get this information. Appreciate any input on this.
SCGraphData ReferenceChartData;
sc.GetChartBaseData(ChartNumber, ReferenceChartData);
int rBarNum = ReferenceChartData.GetArraySize() - 1; // Number of Bars in the referenced Chart
double rLast = ReferenceChartData[SC_LAST][rBarNum]; // This would get the SC_LAST value for rBarNum
SCDateTime rbDateTime = ???? // How to Get the DateTime of rBarNum from ReferenceChartData?
Date Time Of Last Edit: 2015-01-08 06:19:18
[2015-01-08 07:38:15]
crazybears - Posts: 314
Hi ejtrader
do you want calculate the Bar-Time of bars of a chart and use it on another chart/study ?
[2015-01-08 07:40:56]
take a look here
http://www.sierrachart.com/index.php?page=doc/doc_ACSILRefOtherTimeFrames.php
[2015-01-08 08:42:20]
Sounds like you want to use sc.GetChartDateTimeArray()
[2015-01-08 19:26:40]
Thanks crazybears and SC Team.
yes - I was looking for sc.GetChartDateTimeArray()
Though the exact/containing built-in functions available, for a specific need wanted to use the function this way. In combination with SCGraphData ReferenceChartData & SCDateTimeArray RefChartDateTime - Could get the desired result.
Pseudo Code:
SCDateTimeArray RefChartDateTime;
sc.GetChartDateTimeArray(ChartNumber, RefChartDateTime);
Date Time Of Last Edit: 2015-01-08 19:33:16
