Date/Time: Thu, 12 Nov 2026 09:19:12 +0000
quote board for SC symbols
View Count: 1244
| [2015-01-08 05:55:11] |
| joshtrader - Posts: 569 |
If I open a quote board in SC that runs data provider X, and type in a quote board "GER30" I will see that it identifies the name of the symbol correctly, but I get no quotes. If I open a copy of SC running SC's FXCM feed, a quote board will show that quote correctly. Is there a way to get these symbols to display correctly on data provider X's quote board? Or would running SC's data feed be a solution possibly?
| [2015-01-08 06:10:14] |
You cannot do this. It is not supported and there are no plans for this. You need 2 separate copies of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-01-08 06:19:03] |
If I subscribe to NYSE/nasdaq stocks using SC's feed and type IBM in the quote board for a copy of SC connected to Rithmic, will IBM's quote work? Thanks--
Date Time Of Last Edit: 2015-01-08 06:43:42
