Date/Time: Thu, 17 Sep 2026 03:50:06 +0000
[User Discussion] - data updates
View Count: 1179
| [2015-01-07 19:09:18] |
| User16510 - Posts: 2 |
Hi, I am conected to SC historical data feed but the charts doesn´t update in real time. The clock is ok on my computed, so I don´t know what to do. Nyse TICK is updating all right, but for example SYy does not. I have activated the data feed for the exchange to see this ETF. Another thing I need is to setup the cumulative delta per daily bars to apply on a daily chart and I don´t know haow to do this. Thanks. |
| [2015-01-07 19:25:16] |
| ehlaban - Posts: 50 |
I don't think the the Historical data feed gives real time data
| [2015-01-07 19:43:58] |
We see you have activated the Sierra Chart Real-time and Historical Exchange Data Feed and the US equities exchange. To receive this real-time data, set the Global Settings >> Data/Trade Service Settings >> Service to "SC Exchange Data". Cumulative Delta Bars cannot be used on a Historical Daily chart. Only Intraday charts. Refer to these instructions to create daily bars from Intraday data: http://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php#CreatingDailyBarswithCustomStartandEndTimes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
