Date/Time: Fri, 11 Sep 2026 04:42:02 +0000
left price margin
View Count: 1295
| [2015-01-07 16:20:49] |
| User28682 - Posts: 233 |
Hi, 1)Prices on a chart default to the right side, vertical. Can one have them on the left side only? 2)How do I set the price scaling on a chart to a fixed number and still have the chart scale to current prices in real time? Thanks Tom |
| [2015-01-07 17:56:08] |
1. No. 2. We do not understand this. The only help we can provide you is to refer you to the Scaling documentation: The Chart DOM Scale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
