Date/Time: Sun, 22 Dec 2024 21:51:33 +0000
SC Update/download
View Count: 873
[2015-01-07 16:11:28] |
User83623 - Posts: 1 |
When starting up software, I get the reminder that version 1220 is available for download/update. The instructions say to "download current version" under Help menu, however, there are two options. Please explain the difference between the two update options, for "old spreadsheets" and "new spreadsheets". Thanks! |
[2015-01-07 17:26:46] |
This is explained here: Differences Between New Spreadsheets and Old Spreadsheets Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
