Date/Time: Thu, 10 Sep 2026 14:26:25 +0000
Is there a function to 'go to chart number'
View Count: 1390
| [2015-01-07 11:34:22] |
| User34124 - Posts: 289 |
Hi at the moment I am using AHK to point the the CW menu and select charts. This proves difficult when wanting to go to the same chart in a different chartbook, as under CW the charts are organised numerically by timeframe instead of chart number. Which makes no logical sense at all. A solution to make AHK point to specific chart numbers is required. I.e. select chartbook 1, go to chart #8, etc Thanks |
| [2015-01-07 18:10:20] |
The CW menu is sorted alphabetically by the chart name which consists of the Symbol, the timeframe per bar, and the Chart Number. We will add an option to sort it by chart number. We could add a command to the Chart menu to go to a particular chart by its number. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-01-07 20:50:30] |
That would be ideal. If easier for you guys, even incorporating the ability to assign hotkeys for menu commands may be a simpler fix, as here: http://www.sierrachart.com/index.php?page=doc/doc_GlobalSettingsMenu.html#CustomizeKeyboardShortcuts Date Time Of Last Edit: 2015-01-08 13:41:05
