Date/Time: Sun, 22 Dec 2024 21:39:04 +0000
seperate positions
View Count: 890
[2015-01-06 22:19:58] |
User12089 - Posts: 361 |
When Trading/Simulation is enabled on a chart, the default behavior is to average and consolidate as ONE all positions opened in the same direction - ie they are visualized as a single line on the chart. Is there a config setting to represent each open position on its own ie as a separate line on the chart - I had a look but could not find any |
[2015-01-06 22:35:03] |
No.
