Date/Time: Sun, 22 Dec 2024 21:56:56 +0000
Initial set up - finding symbols
View Count: 880
[2015-01-06 19:01:56] |
User43999 - Posts: 3 |
The only categories of symbols available to me are under the umbrella of CFD, Forex and Market Stats. I'm looking for the ES an NQ - E-mini symbols and can't find them. Did I do something incorrect with my initial install? Thank you |
[2015-01-07 09:18:18] |
Use the Sierra Chart Historical Data service for data on futures: Sierra Chart Historical Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
