Date/Time: Sun, 22 Dec 2024 21:35:18 +0000
LOGIN ISSUES
View Count: 947
[2015-01-06 14:51:15] |
User64965 - Posts: 1 |
I CANNOT GET QUOTES OR DOME TO FUNCTION
[2015-01-06 16:21:20] |
Your account has been activated and/or reset. A restart is necessary if Sierra Chart is already running. Exit the Sierra Chart charting and trading software by selecting "File >> Exit". Open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends, you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
