Date/Time: Sun, 13 Sep 2026 06:29:45 +0000
why Rithmic performs periodic disconnection?
View Count: 1343
| [2015-01-06 11:29:31] |
| User82722 - Posts: 18 |
User Message: Tell me, please, why Rithmic performs periodic disconnection? What is the cause and how to fix it. The platform Rithmic work successfully, there is no connection breaks. Version SierraCharts 1222. ---------------------------------------- Selected Data/Trading service: Rithmic Trading ---------------------------------------- Log: Rithmic Trading | Port for executable: 50314 | 2015-01-06 14:13:09 Listening socket (2288), port 50314 | Closed. | 2015-01-06 14:13:09 Rithmic Trading | Starting server: F:\SierraChart\Rim\DTCBridge.exe | 2015-01-06 14:13:09 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50314 | 2015-01-06 14:13:11 Socket (81) | Connected. | 2015-01-06 14:13:11 Rithmic Trading | Connected to server. | 2015-01-06 14:13:11 Rithmic Trading | Sending logon request message. | 2015-01-06 14:13:11 Rithmic Trading | Starting the connection process to data and trading service. | 2015-01-06 14:13:11 Rithmic Trading | Logging is enabled. Log file: F:\SierraChart\Rim\Rithmic.log | 2015-01-06 14:13:11 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-01-06 14:13:11 Rithmic Trading | Server Alert: Market Data Connection Opened | 2015-01-06 14:13:14 Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2015-01-06 14:13:14 Rithmic Trading | Server Alert: Trading System Connection Opened | 2015-01-06 14:13:15 Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2015-01-06 14:13:15 Rithmic Trading | Server Alert: PnL Connection Opened | 2015-01-06 14:13:16 Rithmic Trading | Server Alert: PnL Connection Login Complete. Result text: "ok" | 2015-01-06 14:13:16 Rithmic Trading | Server Alert: Intraday History Connection Opened | 2015-01-06 14:13:17 Rithmic Trading | Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2015-01-06 14:13:17 Rithmic Trading | Server Name: SC DTC Bridge. | 2015-01-06 14:13:17 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-01-06 14:13:17 Rithmic Trading | Successfully connected. IB='TopstepTrader'. | 2015-01-06 14:13:17 Rithmic Trading | Trading is supported. | 2015-01-06 14:13:17 Rithmic Trading | Order cancel and replace is supported. | 2015-01-06 14:13:17 Rithmic Trading | OCO Orders supported. | 2015-01-06 14:13:17 Rithmic Trading | Starting real-time market data updates for: ESH5-CME. ID: 1 | 2015-01-06 14:13:18 Rithmic Trading | Received unknown message type from local socket. Disconnecting | 2015-01-06 14:13:18 Rithmic Trading | Deleting API object. | 2015-01-06 14:13:18 Rithmic Trading | Server Alert: Intraday History Connection Closed | 2015-01-06 14:13:18 Rithmic Trading | Server Alert: PnL Connection Closed | 2015-01-06 14:13:18 Rithmic Trading | Server Alert: Trading System Connection Closed | 2015-01-06 14:13:18 Rithmic Trading | Server Alert: Market Data Connection Closed | 2015-01-06 14:13:18 Socket (81) | Closed. No error. | 2015-01-06 14:13:18 Socket (81) | Shutdown and closed. | 2015-01-06 14:13:18 Connection to the external service has been lost. | 2015-01-06 14:13:18 Rithmic Trading | Disconnected from the server. | 2015-01-06 14:13:18 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-06 14:13:18 Rithmic Trading | Port for executable: 50328 | 2015-01-06 14:13:20 Listening socket (2036), port 50328 | Closed. | 2015-01-06 14:13:20 Rithmic Trading | Starting server: F:\SierraChart\Rim\DTCBridge.exe | 2015-01-06 14:13:20 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50328 | 2015-01-06 14:13:22 Socket (82) | Connected. | 2015-01-06 14:13:22 Rithmic Trading | Connected to server. | 2015-01-06 14:13:22 Rithmic Trading | Sending logon request message. | 2015-01-06 14:13:22 Rithmic Trading | Starting the connection process to data and trading service. | 2015-01-06 14:13:22 Rithmic Trading | Logging is enabled. Log file: F:\SierraChart\Rim\Rithmic.log | 2015-01-06 14:13:22 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-01-06 14:13:22 Rithmic Trading | Server Alert: Market Data Connection Opened | 2015-01-06 14:13:24 Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2015-01-06 14:13:24 Rithmic Trading | Server Alert: Trading System Connection Opened | 2015-01-06 14:13:25 Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2015-01-06 14:13:25 Rithmic Trading | Server Alert: PnL Connection Opened | 2015-01-06 14:13:26 Rithmic Trading | Server Alert: PnL Connection Login Complete. Result text: "ok" | 2015-01-06 14:13:26 Rithmic Trading | Server Alert: Intraday History Connection Opened | 2015-01-06 14:13:27 Rithmic Trading | Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2015-01-06 14:13:27 File >> Disconnect selected. | 2015-01-06 14:13:27 Socket (82) | Shutdown and closed. | 2015-01-06 14:13:27 Rithmic Trading | Disconnected from the server. | 2015-01-06 14:13:27 ------------------------------------------------------------ Date Time Of Last Edit: 2015-01-06 16:10:29
| [2015-01-06 16:19:57] |
This is the problem: Rithmic Trading | Received unknown message type from local socket. Disconnecting | 2015-01-06 14:13:18 This problem has been resolved. Update Sierra Chart to the latest release by selecting Help >> Download Prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-01-06 18:02:54] |
Yes, old version was 1221, new = 1222 - all ok... |
