Date/Time: Sun, 22 Dec 2024 21:37:21 +0000
automatic disconnection of data feed ?
View Count: 931
[2015-01-06 04:09:39]
Trader Ra - Posts: 87
I can see that its possible to set a time for SC to automatically connect to the data feed under Advanced settings in Data/Trade window but is it possible to automatically disconnect the data feed at a set time ? Is this hard to implement ? I couldn't find any documentation on it.
[2015-01-06 08:20:36]
Use a program called Auto Hot Key.
Program a script that sends Sierra Chart the keyboard shortcut to disconnect from the data feed at the time that you want. Keyboard shortcuts for all menu commands are configurable through Global Settings >> Keyboard Shortcuts.
Date Time Of Last Edit: 2015-01-06 08:20:51
