Date/Time: Sun, 22 Dec 2024 22:03:01 +0000
[User Discussion] - Spreadsheet Trading Backtest--Trades Carry Over During Holidays
View Count: 1579
[2015-01-05 20:15:05]
User13863 - Posts: 10
Dear Support,
Thanks for a great platform.
One thing I've noticed when backtesting from a spreadsheet trading study is that it can be difficult to stop trades entered near the end of a day from carrying over to the next day's session during Holidays.
I understand that it is possible using the various J column cells to restrict auto trading, flatten positions, cancel orders, etc. at the end of the day by monitoring the current bar time values. However, during days where a session ends at an irregular time a backtested trade simply carries over to the next session.
Of course, I could program a custom trading study to ignore those Holiday times or I can go through the trade activity tab afterwards and delete the erroneous trades but both of these methods are cumbersome.
A great program could be made better if an auto end of day close trade feature were implemented.
Cheers;
Date Time Of Last Edit: 2015-01-06 01:44:22
[2015-01-05 21:13:01]
Sawtooth - Posts: 4141
The only way to do this is to create a table of holiday trading times, as in the example spreadsheet attachment.
Then the J28 formula needs to reference it with a lengthy formula, as in the text attachment.
Also, there are things you can do to automatically exit trades after the disable autotrading window:
http://www.sawtoothtrade.com/example-4.html
Date Time Of Last Edit: 2015-08-14 02:16:50
attachmentholiday J28 formula.txt - Attached On 2015-01-05 21:07:06 UTC - Size: 396 B - 555 views
attachmentHolidaysES.scwbf - Attached On 2015-01-05 21:07:45 UTC - Size: 6.02 KB - 536 views
[2015-01-06 01:49:36]
tomgilb,
Thank you for your prompt reply. Happy New Year.
[2015-01-06 08:19:18]
An end of day close position feature could easily be done as a study.
Create an ACSIL trading study that uses sc.UpdateAlways and examines the current time or the time of the last bar in case of replay. When there is a nonzero position and the appropriate time is reached, then submit an offsetting order.
Date Time Of Last Edit: 2015-01-06 09:35:39
