Date/Time: Mon, 23 Dec 2024 01:20:15 +0000
Volume per bar
View Count: 887
[2015-01-05 14:49:37]
trader1 - Posts: 128
I am using volume per bar under chart settings and since Jan 2nd there are way too many bars showing up. The overall volume has not changed much, but the number of bars is many times what it was before January. I have not changed any settings or version number. I have split data records unchecked, but I have tried both ways and it doesn't make a difference. Can you please tell me what the problem is and how to correct it?
Thanks.
[2015-01-05 17:06:34]
The only way we can help with this is to have you re-download the data following the instructions in help topic 2.1.2:
http://www.sierrachart.com/index.php?page=doc/helpdetails2.html#h2.1.2
Let us know the time zone setting you have Sierra Chart set to.
