Date/Time: Mon, 23 Dec 2024 01:50:54 +0000
I can not see the angle of the line
View Count: 830
[2015-01-04 16:44:24] |
User63440 - Posts: 1 |
Just started with my free Trial. When I draw a line on the graphic I can not see the angle of the line. I click the right buttom of the mouse to choose Chart Drawing Properties of the line and after that Label, but I can not choose the angle, neither Time Difference, neither other properties. Any help? |
[2015-01-04 20:01:59] |
ehlaban - Posts: 50 |
Use the Chart calculator http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartCalculator |
[2015-01-04 20:05:19] |
Yes, use the Chart Calculator tool documented here: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartCalculator Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
