Date/Time: Mon, 23 Dec 2024 01:26:56 +0000
Naked close
View Count: 904
[2015-01-03 20:43:56] |
sixsmith07 - Posts: 13 |
Is there a way to extend naked close (gap) in my daily chart. I want to have the close extended until it is intersected. I know this is possible for the vbp studies (vpoc and value area) but I need it for close as well. Thanks
[2015-01-04 14:11:51] |
No one? I'm assuming this means it can't be done?
[2015-01-05 06:57:18] |
We have been thinking about adding this capability but it is not so simple. We are still thinking about how best to do this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
