Date/Time: Mon, 23 Dec 2024 02:02:53 +0000
Is it possible to run the scanning in the background periodically like every 15 or 30 min ?
View Count: 1179
[2015-01-03 08:52:56] |
User64764 - Posts: 5 |
Hi, I have setup a simple Alert in multiple charts like Daily/1hr/30m/15m. I see an option under CHART menu to START the Scan and STOP the scan. Is it possible to setup this scanning to start every 15 or 30 min? Please advise.. Thanks Raj |
[2015-01-03 18:47:13] |
These symbol alert formulas are continuously monitored as long as they are on open charts. Did you want the alert formulas evaluated across multiple symbols? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-01-03 19:17:22] |
Yes. That is exactly what I want.. The chart may not be open but I want the Alerts be evaluated continuously and send me an email. I am aware of the Watch list option under chart menu and the Start Scan and Stop Scan option which will either go thru the Watch list or all of the data files in your Sierra data folder. What I am looking for is -- some sort of a background job running every 15 or 30 min across multiple symbols and multiple charts for each of those symbols so that I can get the Alert email promptly.. I would really appreciate your help.. thanks Raj |
[2015-01-03 21:27:07] |
It is not possible to automatically start a scan, but if there is a reasonable number of symbols you want to monitor the alert formula on, even a large number, just open the charts for them and put the Simple Alert Formula on the charts or the studies. You can load a minimum amount of data in each chart and minimize the chart windows so there will be very little CPU impact from them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-01-04 00:18:28
[2015-01-03 23:00:44] |
Thanks a lot for such a fast response.. and also for the useful suggestion.. Thanks again |
