Date/Time: Mon, 23 Dec 2024 01:43:19 +0000
Print the entire chart
View Count: 828
[2015-01-02 18:10:00] |
miami845 - Posts: 7 |
I need to print few days of profiles. When I do the print now, it only prints the data that is visible on the screen. There is much more data on the left side, if I scroll the chart. Is there a way to print all of that in one shot instead of me dragging the scroll bar a million times to set the visible area & print in sequence. Thanks in advance. |
[2015-01-02 18:30:42] |
No, this is not supported. The only thing we can suggest is to reduce the bar spacing in the chart by following the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ChangingBarSpacing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
