Date/Time: Sun, 22 Dec 2024 21:22:08 +0000
New CME data fees and integration with Interactive Brokers
View Count: 1625
[2015-01-02 16:16:19] |
User23815 - Posts: 210 |
I activated the new CME subscription with SC today. I also keep my IB Trader Workstation open as well and have had real time and market depth data showing there. I have received notice from them that the new CME fees(substantially higher than yours, thank you SC)are necessary to see realtime quotes in TWS. Is there, or is there any plan to allow my SC based data to flow through to TWS? If not, typically how does a trader set up if they only see realtime data through SC? I talked to IB as well and it seems this whole change is a work in progress but they said that currently only E-Signal data is able to pass through and show on TWS. Any insight you can provide would be appreciated. Thanks
[2015-01-02 18:39:16] |
We are going to be developing a full DTC Protocol server in Sierra Chart that IB can use. Information about the DTC protocol can be found here: Http://www.DTCProtocol.org The DTC protocol server in Sierra Chart should be ready in about three months. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-01-02 18:40:39
[2015-01-05 14:26:48] |
In the meantime, without activating and paying for IB's data feed, where can I verify in real time that my SC data is in fact real time? I always used the IB feed just as a double check to make sure data was current.
[2015-01-07 09:24:51] |
If you are using the Sierra Chart Real-time Exchange Data Feed, then the data is real-time since that is all the service offers.
