Date/Time: Fri, 26 Apr 2024 08:31:53 +0000
eSignal
View Count: 2021
[2013-05-21 11:41:42] |
User74484 - Posts: 6 |
Are there any plans to add eSignal as a data provider? I have another software package that only accepts eSignal, this means I have to pay for two data providers to use both. I am sure if you added eSignal you would get more subscibers. Thanks. |
[2013-05-21 17:08:53] |
Sierra Chart is now integrated with E-Signal, but we are waiting for the order form from them to order the service. However, the particular E-Signal service we have integrated with, is not one of their standard services. We would assume it is not going to be compatible with the other program you are using. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-21 17:09:50
