Date/Time: Mon, 23 Dec 2024 02:09:57 +0000
Broker
View Count: 844
[2014-12-30 15:07:22] |
User28366 - Posts: 14 |
Is there a broker that supports Sierra that will allow me to trade futures, futures options, stock options and stocks/etfs? |
[2014-12-30 18:01:09] |
The only one would be Interactive Brokers: https://www.sierrachart.com/index.php?page=doc/IB.php However IB is only recommended for users with a higher degree of technical competency with software because it is a complex system with various potential issues. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
