Date/Time: Mon, 23 Dec 2024 01:18:32 +0000
Can I display an arrow for the change in Color Bar Based On Slope?
View Count: 1310
[2014-12-30 11:39:33] |
User40520 - Posts: 62 |
I want to keep the candle colors the normal green and red but where the Color Bar Based On Slope would change the candles colors I want an arrow instead. Is it possible to keep the standard color changes and add a Color Arrow Based On Slope instead of a Color Bar and if so how? Many thanks. |
[2014-12-31 08:04:03] |
The way this can be done is by using the Color Bar Based on Alert Condition study. It is documented here: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s245 The documentation explains how to display arrows instead of coloring a bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
