Date/Time: Mon, 23 Dec 2024 01:44:01 +0000
DTN IQfeed with OEC trading
View Count: 1716
[2014-12-29 18:07:29]
User56304 - Posts: 33
I'm not able to locate documentation on setting up Sierra with IQfeed data and OEC for trade DOMs (chart dom and trade dom).
Is this possible to configure so that it operates the same way as the Sierra data feed and execution through OEC?
[2014-12-29 18:34:42]
It is not possible to set up IQ Feed in the same way to work with OEC as the Sierra Chart Real-time and Historical Exchange Data Feed, although you can accomplish the same result.
Follow the instructions here:
https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#Sharing
[2015-01-04 07:17:30]
I have done this. It appears the OEC data populates the chart after starting up with IQFEED data, yet it's not as accurate as IQFEED data (for well known reasons).
Is it possible to have IQFEED supply all the chart data except for the Chart DOM and Trade DOM so that the charts are correct and up to date (and I can execute trades via the Chart DOM)?
[2015-01-04 07:37:07]
Yes. If you follow exactly the instructions given here:
A more straightforward solution is to use the Sierra Chart Exchange Data Feed instead of IQ Feed:
http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php
