Date/Time: Fri, 22 Nov 2024 14:17:01 +0000
Updates
View Count: 1723
[2013-05-21 08:59:03] |
Outlander - Posts: 91 |
It would be nice if not changing indicators in new updates as it messes up the spread sheet and the trading system stops working.It is a lot of work to figure out what has happened. And if you have to change any please inform us before the update? Regards Outlander
[2013-05-21 09:12:20] |
What study are you referring to?
[2013-05-21 10:14:07] |
I have use 15 study so I am not sure which one.It might be the Numbers Bars Calculated Values. Had to change after the last update 978.I assume you know what changes you have made. This also happened a couple of updates ago.Getting tired that the columns in the spreadsheet moves. So please don't change the study's if it is not very important. If you change them let us know in advance so we could correct the codes in the spreadsheet and not looking at wrong signals.Regards Outlander
[2013-05-22 22:03:54] |
We do have a plan to develop a solution to this. It must have been the Numbers Bars Calculated Values study because we did add additional Subgraphs that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
