Date/Time: Tue, 29 Sep 2026 20:59:10 +0000
Current price
View Count: 1625
| [2014-12-27 22:41:15] |
| User53601 - Posts: 107 |
Is there a way to access the current price, current High or current Low? I am trying to write a code in ACSIL to draw a line which ends at the the current High or Low. However I can not find an ACSIL data variable which contains the current High or Low. Is it available in ACSIL? |
| [2014-12-27 23:23:47] |
Check this page for sc.DailyHigh/Low: http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Variables_And_Arrays.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-12-28 12:11:46] |
I should have been more precise: I mean the High of the current bar and Low of the current bar. Are these data available in ACSIL? I do not mean sc.High[sc.Index] but the High of the current bar which is not closed yet. I tried to use the sc.High[sc.Index+1] but seems it is not giving the value. Date Time Of Last Edit: 2014-12-28 12:15:37
| [2014-12-29 04:07:25] |
Refer to the documentation here: Working with ACSIL Arrays and Understanding Looping This is an example of what you will need to use: sc.High[sc.ArraySize -1] Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-12-29 18:27:45] |
It helped. Thank you. |
