Date/Time: Sat, 21 Dec 2024 15:38:11 +0000
Trade window, 3 targets?
View Count: 829
[2014-12-27 03:09:20] |
User48557 - Posts: 138 |
I am unable to set up a order where i can trade 3 contracts with one common stop and 3 separate targets. Is this function possible ?
Attachment Deleted. |
[2014-12-27 07:49:59] |
Yes this is no problem at all. All you need to do is press the Add button on the Targets tab to add another Attached Order and make sure the type is set to Target: Limit and set the Group to OCO Group 3. On the Main tab set the order Quantity to 3. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-27 07:50:21
