Date/Time: Wed, 16 Sep 2026 03:16:25 +0000
CME market data cost
View Count: 1478
| [2014-12-26 17:36:13] |
| AKR - Posts: 542 |
I received an email by AMP, stating that I need to select a market data subscription as customers need to pay from 2015 due to CME regulations. $5 per exchange. I guess when I have a subscription of the SC feed I can choose "deactivate market data" and everything will run as before, right? Will your charges also increase due to this? I remember you mentioned this issue and it was up to the point of time, when someone subscribed to your feed ??? Thx & merry x-mas :-). |
| [2014-12-26 21:07:04] |
If you are using the Sierra Chart Exchange Data Feed, deactivate it here: https://www.sierrachart.com/usercp.php?page=MarketDataFeedFeatures Refer to this section here for exchange fees: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-12-27 07:43:55] |
| AKR - Posts: 542 |
no no, I do not want to deactivate your feed. My question is just that so far I could also use the AMP feed. But from now on it will cost a bit. The question is now: I can completely deactivate the AMP feed, right, because I will not need it at all. Or do I need it for any functionality having the SC feed anyway? |
| [2014-12-27 07:55:02] |
You can completely deactivate the AMP/TTNet data feed if they make that option available.
