Date/Time: Sat, 19 Sep 2026 03:40:35 +0000
IB Backfill
View Count: 1276
| [2014-12-26 17:34:20] |
| User54903 - Posts: 2 |
I open a chart and go to chart settings and for "number of days to load" select "1" and get the following result: ...... HD Request # 4 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2014-10-16 10:59:00 for GOOG | 2014-12-26 12:25:16 HD Request # 4 | Processing historical data message from TWS | 2014-12-26 12:25:17 HD Request # 4 | Received 2680 records and wrote 1792 records from 2014-10-14 18:59:00 to 2014-10-16 10:58:30. | 2014-12-26 12:25:17 HD Request # 4 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 6060549. | 2014-12-26 12:25:24 HD Request # 4 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2014-10-17 10:59:00 for GOOG | 2014-12-26 12:25:24 HD Request # 4 | Processing historical data message from TWS | 2014-12-26 12:25:25 HD Request # 4 | Received 2752 records and wrote 1920 records from 2014-10-15 18:59:00 to 2014-10-17 10:58:30. | 2014-12-26 ....... It appears to be downloading a bunch of 1 days, but I want only 1 one day. |
| [2014-12-26 21:08:18] |
That setting does not control the amount of days downloaded from the data service. This is explained here: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#DaysToLoad Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-12-29 14:28:19] |
What do I do if I want 1 day?
| [2014-12-29 17:55:28] |
You need to adjust the Maximum Historical Intraday Days to Download setting: Data/Trade Service Settings: Common Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
