Date/Time: Sun, 08 Sep 2024 00:19:14 +0000
Spreadsheet Undo Button
View Count: 1328
[2014-12-26 10:05:31] |
heavyhucks - Posts: 18 |
The undo button seems to be constantly "frozen" and unable to work no matter what I do - both when I right click on the formula bar on the spreadsheet and when I access it through the "spreadsheet" tab. Any suggestions? Regards, James |
[2014-12-26 20:13:28] |
This command is not available with New Spreadsheets.
[2014-12-27 00:33:45] |
OK thank you. I think it would be helpful if it is possible to implement in the future.
[2015-03-12 13:19:06] |
phaedonk - Posts: 352 |
Seriously, I cannot believe that an undo button does not exist in the new spreadsheets. I am using a modified quote spreadsheet to size my positions and this is just one of the problems I could mention with the new spreadsheets vs excel. Problem is I cannot use excel with a quote spreadsheet, but only with a ss study. Can you make a modification there, so I can open my sizing file with excel? |
[2015-03-12 19:59:21] |
We will look into adding an Undo feature for New Spreadsheets.
[2015-06-16 18:37:53] |
User930315 - Posts: 55 |
I'd like to make another request for an Undo function. I've just started using SC spreadsheets and sometimes have the wrong cell selected when I enter data. With an undo function I can fix it one keystroke. Without it I have to go back, figure out what I had in the cell and enter it again. Having to do that with complex formulas is a recipe for errors.
[2015-06-16 18:38:43] |
This task for undo for spreadsheets has been canceled due to the major complexity of implementing it.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-16 18:38:52
[2015-06-16 19:13:57] |
No problem, I have given up on the spreadsheets and gone back to excel anyway.
[2015-06-17 20:57:36] |
OK. We will look into adding a more simple version of undo capability. I think what went wrong with this we had too big of an objective at first. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-17 21:21:27
[2015-06-18 01:10:49] |
A limited multi-level undo (say 3 to 5 levels) would be plenty for my use in nearly all situations. If that involves major complexity to implement, even a one level undo would be a huge improvement and make the spreadsheets much more usable, at least for me. |
