Date/Time: Sun, 19 Jan 2025 15:18:37 +0000
In Asian session today, Dec 26, Sierra Chart is frozen, not moving while all other charts are mo
View Count: 1304
[2014-12-26 04:01:57] |
gold757 - Posts: 39 |
Gold moved a lot in other charts this Asian morning but no change in Sierra Chart. What happened to Sierra Chart today this Asian morning?
[2014-12-26 04:41:30] |
You are referring to the Sierra Chart Forex Real-time and Historical Forex/CFD Data Service. There is no trading at the moment on the FXCM system where the data comes from.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-26 08:00:53
[2014-12-26 04:55:34] |
If you set the Service in Sierra Chart to "SC Historical Data" you can look at the GCG15 CME gold futures chart. This will give you delayed historical data.
[2014-12-26 09:24:08] |
The FXCM data feed became available about 3.5 hours ago.
[2018-01-02 02:19:39] |
Most of the charts are not moving right now. Especially HangSeng has'nt been moving since its usual open at 10:15 am. Some reason?
[2018-01-02 02:52:59] |
We are aware of this. The data feed from FXCM is down at the moment. It is an FXCM issue.
[2018-04-14 00:52:32] |
Sierra Chart is not updating its market data since Asian open today. frozen now. How can I help with it?
[2018-04-16 13:06:38] |
At the time you posted this, it was a Saturday and the markets were closed.
