Date/Time: Mon, 23 Dec 2024 01:29:47 +0000
Simple Alert that is able to scan several bars
View Count: 910
[2014-12-25 08:38:45] |
Riche - Posts: 20 |
Hi Sierra, The Simple Alert currently only trigger when a particular bar is aligned with the subgraphs indicator. For example, all 5min bars in main chart which corresponds with subgraphs Stochastic above 80, will be color-coded. The formulae would be = ID1.SG2[0]>80 Now, what I want is, to have 10 bars before Stochastic touches 80, to be color-coded as well. How am I able to that? Thank you very much. |
[2015-01-03 01:58:43] |
To accomplish this requires that an alert formula that reference forward bars using the [] operator. This is explained here: https://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html#ReferencingDataOtherLastBar You also probably will need to use the OR function as well: https://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetFunctions.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
