Date/Time: Sun, 08 Sep 2024 00:14:31 +0000
market replay numbers different
View Count: 875
[2014-12-23 16:33:50] |
User83963 - Posts: 18 |
when I use the Market Replay if I go back a week or more the numbers on my 1 minute and tic charts are different…
[2014-12-23 18:46:24] |
Different in what way? We need more specific details. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-24 18:06:22] |
I rolled replay back to December 10 at 10am.. my tic Chart number is 2047.75. My 1 min number is 2041.00. The flow appears to be correct but not positive…..Have a very Merry Christmas!
[2014-12-24 20:10:14] |
Most likely you are looking at different contract months for the market at that particular point in time. Refer to the documentation here for instructions to determine what contract month you are looking at in each of the charts: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#DisplayingRolloverDatesContractMonths Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
