Date/Time: Sun, 27 Sep 2026 18:01:25 +0000
SC keeps disconnecting from IQfeed
View Count: 1263
[2014-12-23 15:33:00]
ariknoi - Posts: 31
I sent you the log of SC
pls advice
thanks
[2014-12-23 18:23:09]
When posting on the support board, it is required that you use the same Sierra Chart account that you have logged into Sierra Chart with. To do this select Help >> Support Board.
Otherwise, we have difficulty with finding the Message Log.
[2014-12-23 18:26:24]
Find out from IQ Feed, about why every minute, they are sending this message:
IQFeed | Level 1 system message: SERVER DISCONNECTED | 2014-12-23 10:31:18
Obviously, it is because the server is disconnected but why is it happening so frequently.
