Date/Time: Sat, 26 Sep 2026 15:36:14 +0000
advice using SC on 2 different pc's in 2 time zones
View Count: 1194
[2014-12-23 14:08:44]
User22396 - Posts: 191
I use SC on 2 separate work computers in 2 separate time zones, US MST and CST...in order to not have contract start time problems I have set the MST pc to CST this way when I transfer chart files back forth between pc's I don't have to change the times...
I am sure there is a better way to set up SC to use across time zones without having to cheat by adjusting the PC clock? like with CQG I just set CQG to use 'line time' which is the datafeed clock.
thanks
[2014-12-23 18:47:53]
You can set Sierra Chart to use any time zone you want and this is documented on this page here:
Time Zone Setting
Date Time Of Last Edit: 2014-12-23 18:48:02
