Date/Time: Sun, 13 Sep 2026 01:19:23 +0000
не дает убрать отложенный ордер
View Count: 1319
| [2014-12-22 16:13:56] |
| User17632 - Posts: 10 |
при ликвидации позиций выставляется отложенный ордер pending cancel, и не дает с ним не чего делать. не дает возможность двигать его, или отменить.
| [2014-12-22 17:27:54] |
использую Rithmic для topsteptrader
| [2014-12-22 18:56:17] |
There are several reports of this problem today. This is going to be an issue on the Rithmic side from what we can see. If you cannot cancel an order, contact your broker to cancel the order. Also select Trade >>Refresh Trade Data From Service, to see if the order becomes canceled. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
