Date/Time: Sat, 03 Oct 2026 00:02:33 +0000
protocol mismatch
View Count: 1237
| [2014-12-22 07:26:56] |
| 4646ed - Posts: 231 |
what is a protocol mismatch? I've been getting this message frequently in my message log-should i worry about it? What can i do about it? I have sent the log for analysis.
| [2014-12-22 07:41:00] |
We are aware of this. It is nothing of concern. DTC protocol versions 4 and 5 are completely compatible with each other. Our servers will be updated to version 5 over the next weekend. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-22 07:45:06
