Date/Time: Sun, 08 Sep 2024 00:12:55 +0000
horizontal price lines on chart
View Count: 2090
[2014-12-22 01:36:54] |
User28682 - Posts: 233 |
Hi, can I get horizontal price lines on a chart? On only individuals charts instead of all with a global setting? Last, can I tell the chart what price lines I want? Thanks Tom |
[2014-12-22 03:34:17] |
We need information about specifically what you want with "horizontal price lines". This is too vague. From what we understand we recommend using the Horizontal Lines study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-22 03:46:09] |
For starters, I just want horizontal lines at prices levels. Tom |
[2014-12-22 03:46:52] |
Therefore use the Horizontal Lines study.
[2014-12-22 04:21:39] |
I dont want to draw a horizontal line every .10 on a price chart...dont you have a setting that automatically draws lines at price levels depending on the scaling? Tom |
[2014-12-22 08:06:30] |
Possibly you are interested in the Horizontal Grid: https://www.sierrachart.com/index.php?page=doc/doc_ChartMenu.html#grid Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
