Date/Time: Tue, 29 Sep 2026 20:58:47 +0000
Installation Drive
View Count: 1292
| [2014-12-22 00:30:57] |
| User28366 - Posts: 14 |
I previously installed Sierra on my C drive. Will it cause any problems if I install Sierra to my D drive? If so, are there any special instructions to follow? The reason I am asking is that I have several programs already running on my C drive and I am trying to free up the C drive a little. |
| [2014-12-22 03:37:25] |
There is no problem with this. You can install Sierra Chart anywhere that you require.
