Date/Time: Fri, 18 Oct 2024 03:43:30 +0000
DateTime of last Tick (Replaying)
View Count: 1060
[2014-12-21 19:37:05] |
sbsierra - Posts: 71 |
I currently use sc.BaseDateTimeIn[sc.Index] to get the start time of the current bar. Q: Is there a way to get the DateTime of the last tick instead of the start time of the current bar. I need this to avoid trading during news times and it needs to be compatible / accessibel during replaying. thanks. bs.trader |
[2014-12-21 20:40:14] |
Use sc.LatestDateTimeForLastBar Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scLatestDateTimeForLastBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-21 20:40:24
