Date/Time: Thu, 17 Jul 2025 03:18:21 +0000
Request for new setting on Volume by Price
View Count: 1059
[2014-12-21 18:15:25] |
User24187 - Posts: 54 |
On the 'Display Volume in Bars' Input: Is it possible to include an option to display cumulative volume % on each bar?
[2014-12-21 20:28:38] |
How would this be calculated? What is meant by "cumulative"?
[2014-12-21 20:36:16] |
Currently there is an option called 'Percent of Total Volume', which appears on every bar. Cumulative volume % would represent the total of the volume that occurred on any given bar + all the volume that occurred in the prior bars. The cumulative addition can be started either from top or bottom. Either option is fine, as long as there is a way to tell the total % of volume that has occurred 'behind' a given price level. |
[2014-12-23 02:08:49] |
Do you think it will be possible to offer this option?
