Date/Time: Wed, 27 Nov 2024 06:48:31 +0000
Ehlers Butterworth filter and New User
View Count: 3052
[2014-12-21 12:13:36] |
ehlaban - Posts: 50 |
After years and years of trying Sierrachart for a month and experimenting with it, i recently switched and made it my main platform. Without hesitation this time i paid for a full year. All in. I love the value for money and the design principles. It's smooth and fast. As i'm a drawing / geometry kind of analyst i do miss some small things. One of the things i started doing is experimenting with Acsil and porting some indicators. Without the documentation and more important the code from GANZ i couldn't have done it. The attached indicator is the Ehlers 3 pole Butterworth filter. The standard version, the ehl version is almost identical to his Super smoother filter. |
ehlEhlersButterworth.cpp - Attached On 2014-12-21 12:10:42 UTC - Size: 2.8 KB - 721 views ehlEhlersButterworth.dll - Attached On 2014-12-21 12:11:11 UTC - Size: 17.5 KB - 476 views |
[2014-12-22 08:05:52] |
Thank you for this. Could we add this to the User Contributed Studies list in Sierra Chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-22 08:14:12] |
No problem. I will post more indicators and you can put them in the list as well.
[2015-02-15 09:13:25] |
I recently discovered that the ALMA indicator http://www.sierrachart.com/supportboard/showthread.php?p=166619#post166619 Has the same output as the/my version of the Ehlers 3-pole Butterworth filter. just a fwiw |
[2023-09-12 01:18:35] |
Sudhirc - Posts: 52 |
As this has been done in 2014, can this be used with the current version of Sierra Chart? Thank you |
[2023-09-12 14:17:00] |
John - SC Support - Posts: 36309 |
There is a study in the "User Contributed Studies" called "Ehlers 3 Pole Butterworth". This is that study.
