Date/Time: Sun, 08 Sep 2024 00:05:06 +0000
Trading DOM
View Count: 1559
[2014-12-21 04:33:35] |
rc7rader - Posts: 144 |
When I click on Open Trading DOM, it opens the Find Symbol window instead of going straight to the Trading DOM. To go to the Trading DOM, I still have to click on the Open Trading DOM window a second time. Can this be fixed so Open Trading DOM actually opens the Trading DOM? I'm a little hesitant using the ChartDOM because it is easy to make a mistake of clicking on the DOM and sending an order when I always move the chart up or down and scale prices. Also, I tried using the Trading DOM window and noticed that it doesn't remember the previous settings I made and location. I always have to reconfigure the trade window setting (I enter 10 cents stop) then detach and remove it, resize the Trading DOM window for the chart and move it back to a desired location on the desktop. I was hoping it would act like a child window to the chart it is associated with like Trade Window and Time and Sales window acts. Also when I resize the Trading DOM, the scale changes when it reaches a certain size and the font also shrinks. I would rather have a fixed font size and 1 cent scale so I can enter my trade precisely to 1 cent accuracy. I hope this can easily be done. Thanks. Date Time Of Last Edit: 2014-12-21 04:34:04
[2014-12-21 21:19:45] |
This most definitely cannot be changed because you need to select the symbol first. Make sure you save the current Chartbook to save all of the Trading DOM settings. Here is the documentation: https://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html There is no possibility that resizing a chart window or Trade DOM will cause the font size to change. That is not even supported. It is only supported with the TPO Profile Chart study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-21 21:20:13
