Date/Time: Sun, 01 Nov 2026 00:28:37 +0000
TPO Merge Profile Suggestion
View Count: 1765
| [2014-12-21 03:26:08] |
| User46129 - Posts: 29 |
A feature that would allow a user to drag profiles to merge (create composite profiles) would be useful. If that's not feasible, the ability to setup a keyboard shortcut for the merge profile function would also be nice. The If this is already available and I've missed it, I apologize. Thanks in advance,
| [2014-12-21 09:43:31] |
The problem with keyboard shortcuts with merging is that it is not known exactly what profiles to merge together because there is no point of reference merely from the keyboard.
| [2014-12-21 14:08:09] |
Maybe a left mouse-click on the initial profile that the user wished to merge and then a keyboard shortcut to indicate the direction and execute the merge(s) from that point? i.e., If I want to start in November and merge several profiles to the left, I would click on the November profile and then hit left arrow until I reach the target profile. A drag and drop feature (CQG has this) would be especially nice, but I realize that it may not be feasible. Thank You for your quick response.
| [2015-06-28 06:31:55] |
We will try to get to this over the next month.
| [2016-05-15 02:56:26] |
Here is the documentation for this feature: https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#KeyboardShortcutsForSplittingAndMerging Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
