Date/Time: Fri, 18 Sep 2026 20:53:25 +0000
Subgraph Draw Style Request
View Count: 1446
[2014-12-20 19:35:52]
Halco - Posts: 92
Maybe there's already a way to do this but I haven't figured it out or found the right draw style (though I think I've tried them all) : The capability to have a line or some kind of marker for an indicator or at a price level that extends from the right side of the chart (right scale) but only by a bit, maybe 1/4 or 1/2 inch. For instance, for pivot point levels, instead of cluttering the chart up with a bunch of lines going all the way across the chart, just have these short lines/markers at the pivot levels extending out a bit from the right side. Thanks!
[2014-12-21 21:22:57]
Something like this is supported. Set the Draw Style to Subgraph Name and Values Labels Only..
Enable the Subgraph Name Label and Value Label that you require.
Date Time Of Last Edit: 2014-12-21 21:23:42
