Date/Time: Sun, 08 Sep 2024 00:00:18 +0000
[User Discussion] - Delta Volume - Definition Questions
View Count: 1237
[2014-12-20 13:28:54] |
djcurcio - Posts: 236 |
when charting Eminis - ES for example, is the Delta Volume calculated using the number of trades (orders) or the number of contracts? If the answer is contracts, is there a way to have the Volume calculated on contracts rather than trades (orders)? Thanks |
[2014-12-20 17:57:03] |
The number of contracts.
[2014-12-21 23:20:34] |
Request = Please consider implementing an option to Delta Volume Bar chart - to allow the user to select either (the current) raw volume differential or a percentage delta setting such as 200% or 300% differential from the previous bar. Thanks Happy Holidays |
