Date/Time: Fri, 18 Oct 2024 04:16:49 +0000
Background Color for the Value Area on Market Profile TOP Chart?
View Count: 1544
[2014-12-19 22:40:00] |
User93103 - Posts: 48 |
Hello: How can one make a different background color for value area on the Market Profile TPOs chart (not for the letters). I am using Rectangle from the Tools, but, when check or uncheck the Letters/Blocks in Own Column, then the rectangle does not function properly. Help! God Bless Ben |
[2014-12-20 00:57:15] |
Refer to Highlight TPO Value Area and Point of Control in this section here: https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#TPOProfileSettings It has complete documentation for this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
