Date/Time: Sat, 19 Sep 2026 11:21:19 +0000
how to create a voice alert.?
View Count: 3611
| [2014-12-19 19:22:59] |
| User48557 - Posts: 138 |
After going to Global settings then to General settings, i click on the (Alert/general 3). Then towards the bottom it says "text to speech wave file creation", I would enter a word then press create and nothing happens? How do i locate and use these words that I am apparently creating. |
| [2014-12-19 21:19:57] |
I figured it out, no worries anymore
| [2014-12-20 00:51:55] |
You need to activate this feature here: https://www.sierrachart.com/usercp.php?page=TTS You should get a message in the Message Log like this: Unable to create Text To Speech wav file due to error: ERROR - Text To Speech is disabled for the account. Select 'Help >> Account Control Panel >> Text To Speech Alert Generator' to enable. | 2014-12-19 14:50:21 * If you do not see this select Window >> Reset Windows. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-12-20 01:09:01] |
| Sawtooth - Posts: 4354 |
You can create text-to-speech .wav files for free here: http://www2.research.att.com/~ttsweb/tts/demo.php |
| [2021-06-08 16:40:35] |
| User716220 - Posts: 1 |
Good day support, im getting windows error code 122:'the data area passed to a system called is too small' when i select a wav file for alerts on the general settings. Could you help with this matter? how can this be solved? Thanks in advance for your time.
| [2021-06-08 17:18:13] |
| John - SC Support - Posts: 47939 |
Check to ensure that the .wav file that you are selecting actually is playable. It sounds like you may have a bad file. Just try to play the file using a standard Windows tool, like Windows Media Player. If you can not play it in that tool, then there is a problem with the file. Otherwise, if it can play, but you are just having a problem within Sierra Chart, then let us know, as we would have to figure out why this would occur. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
