Date/Time: Sun, 08 Sep 2024 00:28:47 +0000
Numbered Lines
View Count: 829
[2014-12-19 19:18:01] |
User772383 - Posts: 3 |
Hello, Not sure what I did to cause numbers to appear on all the lines I have drawn on my charts, but, how do I make them go away? |
[2014-12-20 00:41:53] |
Select Tools >> Pointer.
