Date/Time: Tue, 22 Sep 2026 08:44:53 +0000
Tpo and data feed
View Count: 1554
[2014-12-19 17:59:46]
User95521 - Posts: 53
I have some questions:
1. Could you please tell me how to get 120 min TPO chart?
2. If use "Delta divergence" and "TPO" study, which kind of data feed is better?
Thank you!
[2014-12-20 00:51:24]
1. Follow the step-by-step instructions here:
https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#BasicInstructions
2. Any data feed should work fine with the TPO Profile Chart study. We cannot comment on Delta divergence. That is not a Sierra Chart Bilton study.
[2014-12-20 19:41:09]
Thank you very much for your reply.
1. Is it correct in the chart below to get 120 min TPO chart?
2. In FX markets, is it correct to use all the default setting of TPO chart study?
Sorry for my poor English and more poor comprehension...
Thank you!
Regards!
image1.jpg / V - Attached On 2014-12-20 19:39:44 UTC - Size: 532 KB - 592 views
[2014-12-20 21:56:54]
1. Do you want each entire TPO profile to be 120 minutes?
2. Default settings should be fine.
[2014-12-20 22:44:36]
I don't want each entire Tpo profile to be 120 minutes.
(Perhaps it's hard to get this result?...)
I Just want to make the entire TPO profile chart turned into based on 120 minutes data.
For example, in CQG's market profile study, we could set "MP INTERVAL" to 30 min, 60 min or 120 min to get different result.
So I want to know how to adjust the setting in sierra chart.
Thank you!
Regards!
[2014-12-21 01:51:01]
Therefore, it sounds like you do want to change the TPO Letter/Block Time Period Length in Minutes to 120 minutes.
Date Time Of Last Edit: 2014-12-21 01:51:43
[2014-12-21 03:18:45]
Ok, Many thanks for your help!
Merry Christmas!
