Date/Time: Sun, 08 Sep 2024 00:24:42 +0000
M6E - Historical Data
View Count: 1115
[2014-12-19 16:55:48] |
infpz - Posts: 826 |
Can we get more historical data for the M6EH5 contract? Making it continuous does not get more data like normal. I think the historical symbol is MFH15.
[2014-12-19 17:24:16] |
Are you referring to a Historical or Intraday chart?
[2014-12-19 17:27:38] |
historical
[2014-12-19 21:49:19] |
This is now set up. If you restart Sierra Chart you will get the updated symbol settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-20 00:56:23] |
When we tested this, this is the reason why it occurs: MFH15/M6EH5 [C] [M] Daily #15: Date based rollover rule not defined for symbol. Unable to build continuous futures contract chart. | 2014-12-19 12:30:28
MFH15/M6EH5 [C] [M] Daily #15: There are no continuous futures contract symbols. Loading data normally. | 2014-12-19 12:30:28 We will add the rollover rules. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
